headlight modulator
Old Sep 24, 2008 | 01:30 PM
MrModest501's Avatar
Default headlight modulator
I just bought my first bike ('02 F4I Yellow and Black). What are the general thoughts about headlight modulators? From what I've read they are legal as long as they have a sensor that turns it off at night. Anyone have any suggestions of which to buy or easiest to install?
Old Sep 26, 2008 | 12:18 AM
Aken's Avatar
July 2008 ROTM
Default RE: headlight modulator
They're pointless on your F4i, because they utilize a bulb with two filaments. You'd have to swap in a different bulb just to use them, and then both your headlights would be flashing.
I'd just ride with your high beam on during the day, like most people.
Old Sep 26, 2008 | 10:30 AM
MidnightG35X's Avatar
I'm not sure that's true... most headlight modulators just use the high beam, so on the F4i, the high beam only would be pulsing. Both lights would be on, just one would be solid, one would be pulsing.
Old Sep 26, 2008 | 10:56 AM
Aken's Avatar
July 2008 ROTM
Yes, it would work that way. But how ridiculous would it look to have your high beam flashing constantly? I'd get annoyed by that regardless of what I was driving in.
Old Sep 26, 2008 | 11:47 AM
Isn't that how all headlight modulators work? Don't all of them modulate just the high beams? I guess I'm confused when you say they are pointless. If you don't like the pulsing part of it, I understand that and that's why you don't use one. It might look ridiculous to some, but to others its an attention getter and that's what they want. I don't have one, so I'm not defending them because of that, I just wanted to present the other side
Old Sep 26, 2008 | 05:06 PM
I believe they only are allowed to be on durring the day, so I doubt you would see that it was pulsing. Just thought it might grab attention better than just having the high beam on, but it doesnt sound like to many people put them on their bikes.
Old Sep 26, 2008 | 06:01 PM
JimT's Avatar
I have on my SV.
It has a 3 way switch, one for low beam, one for high, and off.
It pulses the light on and off. It would work on the F4i the same way.
It also has a photo cell so it doesn't work at night or in a tunnel or parking garage.
Old Sep 27, 2008 | 01:30 AM
Aken's Avatar
July 2008 ROTM
ORIGINAL: MidnightG35X
Of course that's how they work. But it's normally in a single headlight that has the low beam on consistently. I think it would look retarded to have the F4i's high beam constantly turning on and off like a strobe light. That's my point
Personally I think anything that blinks rapidly like that should be left for emergency vehicles.
Old Sep 28, 2008 | 12:03 PM
I really don’t mind if people think it looks retarded or irritating because that’s what I would be going for, to be noticed! Plus it sounds like something that you could turn off when you didn’t want it on. So that being said, does anyone have a suggestion on brand, or best place to get one? Plus, how hard are they to install?
Old Sep 30, 2008 | 12:10 PM
Jaybird180's Avatar
ORIGINAL: Aken
Constant highbeams have been identified as the common culprit in burned harnesses. It shortens the lifespan due to the current load.
