HANDLEBAR WEIGHT
Old Apr 25, 2008 | 07:02 PM
gr8's Avatar
gr8
Default HANDLEBAR WEIGHT
Any one know if you remove and replace these. I think you can otherwise they would not sell it. On my right handlebar the bar end is ripd off and it took all the bolt threds with it. I got tht bike like that i wann fix it cuz dirt is geting under the throttle. I think its number 8 in the picture its right under the handlebar, if any one knows how too take it apart let me so i can be sure thanks. I think its called handlebar weight. sorry the pik is small
http://i49.photobucket.com/albums/f2...8/HJ510064.gif
Old Apr 25, 2008 | 08:05 PM
ampfp's Avatar
Default RE: HANDLEBAR WEIGHT
it's a PITA. I had to cut my grip, and there's a small hole in the bar there through which I had to poke a screwdriver and pry out the weight.
So going from inside out, there's first
1> the bar weight
2> two rubber washers/grommets slid onto grooves on the weight that hold it against the bar
3> the hollow bar with the small hole
4> grip.
2> is what causes the problem getting it out! The first washer is just inside the hole under the grip. If you can get to it without cutting the grip, more power to you, but I couldn't. So I put in the tiny screw driver in through the hole under the grip and and wedged it between the washer and the handlebar, and pried the weight out while simultaneously pulling on the broken part with pliers. ( The broken part will have part of the hole for where the bar end screw fits in. Use this for the pliers!
Old Apr 25, 2008 | 08:48 PM
gr8's Avatar
gr8
Dam well its gota get fixd so im gona try this saturday. Thanks a lot for the info ampfp.
Old Apr 25, 2008 | 09:29 PM
bluej511's Avatar
Use the bolt that holds the bar end on, screw it in and bit and use the bolt to pull the weight out. My spray some wd40 in there or just some water or something to help it slide out, theres 2 rubber grommets that keep the weight in place
Old Apr 25, 2008 | 10:49 PM
simmadown's Avatar
I just put on heli bars and let me tell the handle bar weigt removal was the worst part! since i was putting on totally new bars i ended up cutting the old bars in half. and the clips arent really reusable either.
Old Apr 26, 2008 | 02:45 AM
Gone_Broke's Avatar
A slide hammer with a 6 or 8 mm ( cant remember which) screw works great. I put on a set of manic salamander bar ends with cruise controll in under an hour.
Thedevinestman
Sep 29, 2013 08:27 PM
sluijs01
Jul 19, 2011 04:32 AM
SIRGERMAN
Dec 20, 2007 10:44 AM
Bakazan
Jul 15, 2007 10:59 AM
