Handlebar Weight ?
Old Dec 18, 2007 | 10:04 PM
SIRGERMAN's Avatar
Default Handlebar Weight ?
[align=left]c
can you tell me what it is for ?
[/align]
Old Dec 18, 2007 | 11:04 PM
thecap's Avatar
Default RE: Handlebar Weight ?
It goes inside the bar to reduced vibrations. The OEM external bar end/weight is attached to this by a bolt. I had to buy one of these when switching from a light weight bar end held by compressed rubber to the heavier OEM bar end and discovered the internal weight's thread was stripped. Then my friend had a wreck and broke the other internal bar weight when the bar hit the ground. He's a good guy and replaced it.
IIRC they are $14 new.
Old Dec 18, 2007 | 11:30 PM
SIRGERMAN's Avatar
am i going to see any differents , does it make any sense ?
[align=left] [/align]
Old Dec 20, 2007 | 10:44 AM
thecap's Avatar
If your bar is vibrating too much I would certainly try changing to a different weight to see if it helps. I haven't tried different internal weights with an external weight. Without any weights the vibrations get pretty bad > 6000rpm. If you hold on firmly your arm dampens it a little but you wouldn't want to take a long trip with the bars like that.
You should probably get the rubber rings that hold it in place too.
Thedevinestman
Sep 29, 2013 08:27 PM
sluijs01
Jul 19, 2011 04:32 AM
gr8
Apr 26, 2008 02:45 AM
Bakazan
Jul 15, 2007 10:59 AM
