Gauge cluster question
Old 09-10-2018, 07:34 AM
gamekiller7's Avatar
Default Gauge cluster question
I've got a f3 that I've converted to a RR body and a f4i gauge cluster.
I've already wired the cluster up and I love it, so much better than the analog f3, but I stupidly wired it all up away from the fairing stay. The way I'm mounting the gauge on the stay I need to have the wires ran behind the stay and over the top.
Since I cut soldered and shrink tubed can I disconnect the wires from the cluster itself?
Old 09-10-2018, 01:59 PM
aaaaustin122's Avatar
If you follow the wires down from the cluster to the main harness there's a plug. It plugs into the main harness. At least that is how it is on the F4i. Not sure about the F3. If you do end up having to pull wires apart, just pull them apart by melting the solder so that once you get it where you want it, you just gotta melt them back together. The shrink tubing, you might just have to carefully cut it and tear it off.
Old 09-10-2018, 05:05 PM
Yeah I cut the f4i connections off at the end of the wires and hard wired everything to my f3, I just easier wondering if I can disconnect the wires from the cluster itself. I see it's held in eith two screws but haven't taken it all apart yet
Old 09-10-2018, 05:06 PM
I would assume all the wires are hard-wired inside the cluster.
le nitro
08-12-2012 03:52 PM
otello
09-29-2009 11:34 PM
LiMe_GrEeN_MaChInE
09-03-2008 05:39 PM
Winchester
10-29-2006 01:44 AM
DempsRS
10-12-2006 10:44 PM
Quick Reply: Gauge cluster question
