Go Back  CBR Forum - Enthusiast forums for Honda CBR Owners > Past CBR Models > CBR 600 F4i > F4i - Main Forum
Reload this Page >
Changing Crankshaft. Can I remove the timing chain without removing the head?
Old 09-09-2018, 10:08 PM
Pmartone's Avatar
Default Changing Crankshaft. Can I remove the timing chain without removing the head?
Hello,
I am chaning a bent crankshaft. I have the engine out and I am about to split the crankcase. The last thing standing in my way is the Timing chain. Is there a way to loosen or remove the timing chain without removing the head? What should I watch out for? Will it throw the timing off? I need to remove it form the gear in the diagrams below and then everything can be split.
Old 09-10-2018, 12:32 PM
SunBlue's Avatar
You will definitely need to remove the cct and the head cover to take off camshafts but once you have the camshafts out the chain should come out easy
Old 09-10-2018, 01:03 PM
Pmartone's Avatar
So there is no way to do this without the camshafts coming off. I'm trying to avoid disrupting the timing. Any words of caution?
Thanks,
Pat
Old 09-10-2018, 01:09 PM
74demon's Avatar
By removing the chain and crankshaft, you will already be disrupting the timing. Just make some marks at tdc so it goes back together correctly.
when you get the chain off the cams, put them back on to hold your valve shims in place. This would be a great time to check the valve adjustment and correct as needed.
Old 09-10-2018, 07:27 PM
Cams actually out or not your timing will be off. If you can split cases you can easily set cam timing.
Pmartone
07-10-2018 01:17 PM
zDirtyDeedz
08-24-2016 08:54 PM
MaikuMizu
09-30-2012 10:06 AM
moosestang
03-04-2011 05:35 PM
Quick Reply: Changing Crankshaft. Can I remove the timing chain without removing the head?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
