Fuel pump wont seal on tank
Ok I just read once you take it off you have to replace it. Also the fuel pump seems to be running dry. Does anyone have a diagram of where the fuel lines go where. I think I may have something wrong. I am assembling this as I bought it this way.
You can't really mess up the pressure line. (it's the one with the banjo bolt)
The return line and the overflow line is all that's left. You should be able to figure it out. It not there is a thread close to the top where someone posted pictures. I will link it in a second.
Edit: Here you are...
https://cbrforum.com/forum/f4i-main-...l-help-123137/
I did not know that I just tightened in a lug pattern.
C Jacob W
Jul 29, 2013 11:03 AM
