Fuel pump wont seal on tank
I pulled the fuel pump to drain the gas now it wont seal up. It keeps leaking. Any advice.
Replace the gasket.....
Originally Posted by jp_greenville13
(Post 1032280)
You can't really mess up the pressure line. (it's the one with the banjo bolt)
The return line and the overflow line is all that's left. You should be able to figure it out. It not there is a thread close to the top where someone posted pictures. I will link it in a second. Edit: Here you are... https://cbrforum.com/forum/f4i-main-...l-help-123137/ |
(Post 1032304)
OK well I replaced the gasket and its still leaking bad. I had to put 2 gaskets on it and it seems to stop it but the gasket is still getting wet.
you have to tight the bolt in a certain sequence... look in the manuel if will tell you what bolt to tight first
Originally Posted by oxyg3ne
(Post 1038582)
its hard for people on the internet to figure out what your problem is ... or any problem at all ;p
Where can I get a manual? Online.
