fuel pump
Old Mar 2, 2006 | 10:04 PM
cbrhomie600's Avatar
Default fuel pump
whats up. also i had my bike diagnosed and found found out my fuel pump is not functioning. any help on knowing how to replace one or where i can get one from would greatly be appreciated.
Old Mar 3, 2006 | 04:00 PM
Icefox's Avatar
Default RE: fuel pump
Try looking on eBay, I see quite a few listings for used pumps on there but there might be some new ones listed too. If you're worried about buying a used pump, which I probably would be, they might have some listings for new ones. I've never changed a fuel pump on my bike, but I know after you get the tank off there are a few lines you have to disconnect. After those lines are free it shouldn't be too much work to take the fuel pump assembly out of the tank.
Old Mar 3, 2006 | 08:21 PM
Tahoe SC's Avatar
no sir...but you gots to buy new washers and stuff when you take off the lines...cause they like crush washers. also, some golf tees are good to plug the lines to prevent them from leaking fuel.
it's not too bad...but changing the fuel filter is just as bad.
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
