Fuel problems
Old Aug 1, 2010 | 10:19 AM
thor617's Avatar
Default Fuel problems
i have a 2001 f4i. just bought it bc it didnt run and dumped fuel out the exhaust when they tried to start it....so i was thinking injectors stuck open duh.....i pulled the injectors sent them off and had them cleaned....put it all back together and started it....started perfect except that it dumps gas out the exhaust very bad like...i can put my had behind the header and it will be covered in gas....so i pulled the throttle bodies off and tried to start it. injectors 1 and 4 are spraying perfect but 2 and 3 arent spraying they are like pouring i guess you could say...i swapped 1 and 4 with 2 and 3 and it still did the same thing with the middle two injectors....is it the FPR????ECU???? i hope its not the ecu...please help all info is valued
Old Aug 1, 2010 | 11:03 AM
R Dub's Avatar
October 2011 ROTM
Sounds like the FPR to me. Use the search function and you should find what you need.
Old Aug 1, 2010 | 11:30 AM
thor617's Avatar
thanks
Old Aug 2, 2010 | 12:29 PM
adamw89_2000's Avatar
fpr is the prob
Old Aug 2, 2010 | 08:20 PM
thor617's Avatar
I hopeit is the problem. I'm gonna order the part soon.
Old Aug 3, 2010 | 12:22 AM
Fool's Avatar
ya the fpr has 2 lines that dump into 2 and 3 when it goes bad ,.. it jsut like u said dumpd fuel into those 2
Old Aug 3, 2010 | 08:41 AM
thor617's Avatar
Do y'all kno of a good place to order them from?
jet_cbr_2000
Jul 6, 2010 09:50 PM
slammedxlt
Mar 21, 2009 04:37 PM
ludespeedny
Oct 26, 2008 02:29 PM
laidten
Feb 21, 2008 01:25 PM
hdavid70
Feb 21, 2008 03:55 AM
