thor617 |
08-01-2010 10:19 AM |
Fuel problems
i have a 2001 f4i. just bought it bc it didnt run and dumped fuel out the exhaust when they tried to start it....so i was thinking injectors stuck open duh.....i pulled the injectors sent them off and had them cleaned....put it all back together and started it....started perfect except that it dumps gas out the exhaust very bad like...i can put my had behind the header and it will be covered in gas....so i pulled the throttle bodies off and tried to start it. injectors 1 and 4 are spraying perfect but 2 and 3 arent spraying they are like pouring i guess you could say...i swapped 1 and 4 with 2 and 3 and it still did the same thing with the middle two injectors....is it the FPR????ECU???? i hope its not the ecu...please help all info is valued
