Fuel issue?
Old Apr 24, 2013 | 09:27 AM
hss2010's Avatar
Default Fuel issue?
Cbr f4i. Started it up after sitting for the winter and it ran fine. Didn't ride it. Shut it off. And tried to start again about a week later. Drained the fuel and put fresh gas in it. But wouldn't start. Checked today and I have spark. Tried spraying starting fluid with the air box off but wouldn't fire. Any ideas? Made sure the battery was fully charged as well and checked all fuses. Fuel pump kicks on with key in on position.
Old Apr 24, 2013 | 01:46 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The kill switch didn't accidently get toggled to the other position, did it? Check the simple things first.
Old Apr 24, 2013 | 01:51 PM
hss2010's Avatar
Sorry I'm helping a friend, is there a kill switch for the fuel? If I sprayed starting fluid in there wouldn't it fire any ways?
Old Apr 24, 2013 | 03:03 PM
CorruptFile's Avatar
June 2013 ROTM
The killswitch cuts off spark, not fuel. What does your oil smell like? If it smells like fuel, maybe you had some fuel leak down into the cylinders and kill your compression.
If you have spark and fuel, makes me think compression.
Old Apr 24, 2013 | 04:51 PM
hss2010's Avatar
Same here but it was running fine. Battery fully charged and spark looked good so doubtful it weak spark being the issues. To make sure it's getting fuel should I just put a small amount of fuel through each opening?
Old Apr 24, 2013 | 04:54 PM
June 2013 ROTM
You can washdown cylinders in a few minutes. Try pulling the plugs and putting about a tbsp of oil in each cylinder then try starting.
Old Apr 24, 2013 | 06:11 PM
RoadiJeff's Avatar
If the kill switch is turned off it won't start, no matter what else you do. Up there, next to the throttle grip.
Old Apr 24, 2013 | 07:39 PM
hss2010's Avatar
Roadijeff I have spark as I said in my initial post. So not the kill switch. Fuel or compression issue.
Old Apr 24, 2013 | 08:08 PM
June 2013 ROTM
Are the plugs wet?
Old Apr 24, 2013 | 08:43 PM
hss2010's Avatar
Didn't check forgot my spark plug socket. Ill have to check. If they are then I'm on to compression.
bammerman
Jun 28, 2012 07:06 AM
Kellan
Jun 7, 2012 09:00 PM
Hyperblau
Apr 8, 2012 10:19 AM
daugherty_3
Jun 13, 2010 08:11 AM
EHonda
Jul 3, 2007 10:00 AM
