fuel issue
Old Jun 27, 2012 | 07:19 PM
bammerman's Avatar
Default fuel issue
So I bypassed my fuel pump (after i did the repair to it) and it fires up. Hook the fuel pump back up and nothing just wants to turn over. So since I fixed the fuel pump already with that 40$ part and how-to on this site, what else in the system could cause a no start? Also still getting smoke out the back but do not see any oil leaking out of the exhaust any more. I added seafoam so hopefully when I get it on the road and run a good tank through it the smoking will go away.
Carbs are clean and there is spark so I know that isnt the issue, it is something with the fuel system
Old Jun 27, 2012 | 10:19 PM
colorado_steve's Avatar
so if you run gravity feed straight to the carbs it will start, but if you run the fuel pump inline between the tank and carbs it will not start?
Old Jun 27, 2012 | 11:05 PM
74demon's Avatar
Pump pumping backwards?
Old Jun 27, 2012 | 11:16 PM
bammerman's Avatar
My pump was dead so I followed the repair tutorial on the site, I doubt it would be reverse since I only unhooked the hose going to the tank, is there a filter that could be clogged in-between them or maybe I just need a new pump all together. I do hear the clicks though when I try to start
Steve, I am over in Highlands Ranch, CO. Nice to see a fellow F3'er around the area.
Old Jun 28, 2012 | 07:06 AM
marc0011's Avatar
Make sure your input and output hoses are attached correctly. Hook the pump directly up to a battery. Run the output of the pump into a graduated cylinder.
hss2010
Apr 24, 2013 08:43 PM
Kellan
Jun 7, 2012 09:00 PM
Hyperblau
Apr 8, 2012 10:19 AM
daugherty_3
Jun 13, 2010 08:11 AM
EHonda
Jul 3, 2007 10:00 AM
