front sprocket replacement
Old Oct 1, 2009 | 07:15 PM
fairladylover's Avatar
Default front sprocket replacement
upon removal of the oe front sprocket, i noticed that it is encased in this rubber insert that will not come off (unless torn off).
the new sprocket has no insert.
is this a common issue others have run into?
does the new sprocket not need it?
thanks in advance
Old Oct 1, 2009 | 07:17 PM
dave ls1's Avatar
does not need, throw away
Old Oct 1, 2009 | 09:18 PM
corrado007's Avatar
I agree, it's not needed. I replaced my chain and sprockets a while back and ran across the same issue. The new sprocket with out the rubber part works just fine.
Old Oct 2, 2009 | 02:49 PM
dave ls1's Avatar
To be more specific, only the OEM sprockets have the rubber damper. Not to be used with aftermarket pieces.
acat04f6
Jun 24, 2009 06:27 PM
Dougs88_1000f
Apr 28, 2008 09:58 PM
barclord
Oct 26, 2007 09:09 AM
beebopbogo
Jul 20, 2006 03:52 AM
kroymander
Oct 7, 2005 04:46 PM
