Front end misaligned?
Old Nov 1, 2005 | 05:16 PM
1FastF4i's Avatar
Default Front end misaligned?
Hey guys, when I ride in a straight line, my triple clamp looks like it's turned to the right just a bit. I can coast with my hands off the clipons and the bike tracks perfectly straight, but the bars look slightly turned from the rider's point of view. I checked my rear wheel alignment (just the alignment marks) and it looks okay. Is it possible for the front end to be out of whack? It seems as though the front end would be self-aligning by default once you put the front axle in. Any ideas?
I know this misalignment could be other things, but I'm simply asking if the front forks CAN be misaligned, that way I can completely rule that cause out if not. Thanks.
Old Nov 1, 2005 | 06:39 PM
Tahoe SC's Avatar
Default RE: Front end misaligned?
if they bent then yeth...
Old Nov 1, 2005 | 06:46 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Ya bent -- has it been in a crash?
Old Nov 1, 2005 | 11:14 PM
1FastF4i's Avatar
Fixed it. I loosened the lower triple clamp, axle bolt and pinch bolts and was amazed by how much I could twist the tire back and forth. I straightened it out, and it's good now. Thanks.
Old Nov 2, 2005 | 01:54 AM
Good deal. So what happened before? Was it in there cocked when you tightened it up? Seems like it could've led to a serious case of the shakes at speed -- glad you found it.
Old Nov 5, 2005 | 02:57 AM
1FastF4i's Avatar
Yeah, it was just cocked a little bit I guess. The bike rode great and tracked fine, it just looked like the upper triple was turned a bit and it bugged me. You know how it is. I was thinking all kinds of bad stuff from my lowside.... But no biggy. I think my rear wheel is a tiny bit misaligned too, which could be causing it because it's still not perfect. I did the string trick on the rear wheel and it looks like it's off a couple turns of the chain tensioner.
Nero
F4i - Wanted
Jul 31, 2011 03:22 PM
bammerman
F3 For Sale / Trade
35
Aug 4, 2010 09:40 AM
Footnfool
May 24, 2010 03:19 AM
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
Hayden06F4i
May 3, 2008 09:35 PM
