Front brake sticking after changing pads
Old Mar 1, 2013 | 02:08 AM
wetawded87's Avatar
Default Front brake sticking after changing pads
Had a shop change the pads on my bike recently (06 f4i). Since I picked it up I noticed a new noise coming from the front wheel... It sounds like sssssk ssssk, imagine sharpening a knife. Would be the best way to describe it, anyway I checked it out and my front brakes are sticking. When I release the lever it dosnt reset all the way... I called the guy and he said its probably the master cylinder. Anyone here think differently? The fluid is topped off. Also I didn't notice this before the new pads.
Old Mar 1, 2013 | 06:38 AM
Kuroshio's Avatar
Sounds like the mechanic didn't push the pistons back before swapping the pads when he took off the calipers.
When the caliper is remove, the pistons will tend to push out. If not pushed back, the pads will ride the disc. Easiest solution is to take the calipers off, push the piston back in and bleed the brakes. Then try her out.
I suggest doing it yourself. Your mechanic sounds a little shady, suggesting a master cylinder problem.
Old Mar 1, 2013 | 10:10 AM
Sick97SS's Avatar
You had a shop change your brake pads?
and on top of that, they didnt even do it right!
Old Mar 1, 2013 | 10:19 AM
wetawded87's Avatar
Thanks
Old Mar 1, 2013 | 10:20 AM
wetawded87's Avatar
I had a few things done... Not just pads
Old Mar 1, 2013 | 12:09 PM
mnguyen84's Avatar
no no. in order to get the new pads in, you have to push the piston back into the calipers, because the newer pads are thicker. the pads will always ride the rotor to some degree. but if it sounds that bad, then bring it back to the shop to have them look at it.
Old Mar 1, 2013 | 05:32 PM
mnguyen84's Avatar
Theres no shame in taking ur bike in for work done, even if it is minor stuff. people live different lives and everyone has the time nor the interest for such matters
Old Mar 1, 2013 | 08:13 PM
RudyGT's Avatar
im going to have to agree that it doesnt make sense to say the master cylinder has anything to do with the fact that your brakes are engaged.
you can easily enough pop them off, remove the pads, disconnect and watch fluid leave the brake lines, use some of that fluid to clean the outside of the pistons if need be. push the pistons in, spray everything down with brake cleaner and make sure there is no fluid anywhere, and install the pads and calipers, and bleed them yourself with just a hose, bucket and 8mm open end wrench.
yeah well, i took my bike that is under warranty that has to be done at a kawasaki certified shop and it comes back with a leaky valve cover.
at that same time i checked my honda's valves, and no leaks after putting everything back together.
and the cbr pumps more oil through, never thought i would be one of those people who say dont go to the dealer but it seems, to them its a job, to you its your life. plus i would like to keep the foot pounds on bolts/nuts under 250...
Old Mar 1, 2013 | 08:39 PM
mnguyen84's Avatar
not sure why you quoted me becuz what you're saying is unrelated to my response.
Old Mar 1, 2013 | 11:28 PM
stlcbr600f4_newb's Avatar
did you change your brake lever???? i have read sometimes cheap levers the plunger is to deep and causes brake issues.... a just in case addition to the thread
good luck
jeffjones
Oct 27, 2010 12:38 PM
G3NESYS
Apr 11, 2008 12:29 PM
sstgonzo
Aug 17, 2007 01:09 AM
bluestanger66
May 12, 2007 04:17 PM
fading@verizon.net
Oct 17, 2006 07:39 PM
