Flush mount install question
I searched and couldn't find the answer to this question. I think it is such a basic question that most people know the answer...but I don't. I want to put on new flush mount signals and I was wondering what do I have to take off the bike to get to the signals. Can I just take off the black plastic piece that hugs the front sides of the tank to gain access to the back of the signals? Do I have to take the lower fairing off? Or do I have to take the entire upper fairing off?
BTW I have never tore into my bike, so this is all new territory for me.
Thanks for any help.
I'll be curious if you have any issues getting the front cowl back on. Mine is back on, but I can't get the sides of it to "Snap" back in. You'll see what I'm talking about once you get it apart.
Cloots
Ok. Easiest way. Take the black piece in your wheel well off. Then, Take off your side fairings, and plastic beside the tank. On one side I actually unscrewed me ram air vent. Not necessary, made it marginally easier to get at. And didn't even bother screwing it back in. (no change being in or not whatsoever, I'm picky like that).
Once the fairings are off, all you do is force your hand and a wrench up the side, and loosen the nut, once you can get it with your fingers it's cake. You loosen it, take the light out, cut the wires, splice the new one AFTER you put the screw adapter thing back on, you'll know what I'm talking about when you're there.
Then slide your fingers up in and retighten the nut, going all in reverse. Took me about 40 minutes for the whole job.
- Remove side fairings
- Unplug/disconnect factory signals
- Unbolt & remove fact signals
- Install (bolt up) new flush mount signals
- Connect wiring using IndyLeads (allows plug-&-play w/ factory plug connections...no mess). If no IndyLeads available, use quick-disconnect connectors...makes it easier if you ever have to replace them.
- Test function of signals
- Cable-tie wiring bundle & neatly tuck back behind new signals
- Reinstall side fairings
- DONE
