Flush Mount Signal Install help
Old Jun 1, 2012 | 01:45 PM
chris27house's Avatar
Default Flush Mount Signal Install help
Hi Everyone,
I bought these flush mount signal's on ebay spur of the moment. Wondering if anyone has a suggestion on how to secure them. The OEM signals have a bolt on the back, these new signal's do not have a bolt or nut connection.
These are going on a 2001 929rr Erion.
Old Jun 1, 2012 | 02:07 PM
74demon's Avatar
the big plastic nut on the back holds it to the fairing.
take the nut off, put the assembly through the hole, screw on the nut.
wire it up....
Old Jun 1, 2012 | 02:10 PM
estate4life's Avatar
February 2012 ROTM
Depends if the (huge) nylon nut fit between...in the cavity of the outside fairing and inner.
Old Jun 1, 2012 | 04:37 PM
wire it up....
Wow, i was dense on this one. You're certainly correct, the washer screws right off. Problem solved with securing to fairing.
Thanks very much.
Old Jun 1, 2012 | 04:47 PM
February 2012 ROTM
How is it blinking? Super fast?
Old Jun 1, 2012 | 04:48 PM
74demon's Avatar
should be fine, those are not LEDs.
Old Jun 1, 2012 | 04:49 PM
February 2012 ROTM
Sirdemon, this gotta be one of your easy fix thread...I never thought of application, but more of fitment issue...lol
wire it up....
Old Jun 1, 2012 | 04:52 PM
74demon's Avatar
they fit. stealthcbr929 has the same ones. i went with the small ones, not the mini. the faring hole is oval and pretty big. my small ones barely cover it....dont know how he got the minis to cover it. he has aftermarket fairings, so he may have smaller cut outs.
Old Jun 1, 2012 | 04:56 PM
February 2012 ROTM
I see it's 3 wires...how are those set for running lights, do they get really hot..
Old Jun 1, 2012 | 05:00 PM
74demon's Avatar
yes they do, and melt things.
i went with the 2 wire, 194 bulb, turn only. incandescent running lights get too hot.
