Flush Mount Signal Install help
Old Jun 1, 2012 | 05:09 PM
estate4life's Avatar
February 2012 ROTM
Guess only stock w/stem running lights is best suitable...hey but they sell those replacement led bulbs right?
It's nice that it fits right on a 929...that's a big size nut. On a 900, the cavity is only like 3/4" deep before hitting the inner fairing.
Old Jun 1, 2012 | 05:48 PM
chris27house's Avatar
I will run home tonight and install them. I was looking for another stock connector for the harness so I wouldn't have to cut any wires. Perhaps I will be able to push the wires out of the OEM connector.
Also, i am under the impression the third wire on the bulb is for the daytime runners. If I leave that wire disconnected, i should be ok, ya think?
I will let you know how they go.
Appreciate the help.
Old Jun 1, 2012 | 09:31 PM
74demon's Avatar
You will needs to splice the wires into the harness. Splice into the light side of the wiring so you can use the factory connectors.
On the bike:
Green is ground
Orange or blue is running
Orange or blue with the white stripe is turn.
You will need to figure out which is which on the bulb. Just leave the running wire disconnected if you don't want running lights.
Old Jun 2, 2012 | 11:31 AM
Light's will not fit without cutting a larger hole into the inner fairing. The length of the fixture is too long.
Think I will look for a light that doesn't require me to modify the body of the bike.
afpackard
Oct 29, 2012 07:50 PM
06Tribal600RR
Jun 9, 2010 07:27 PM
ks503
Jul 3, 2008 05:41 PM
fiveoh
Mar 20, 2008 03:42 PM
bradfrd24
Apr 4, 2007 10:30 PM
