Flush signal install
Old Oct 29, 2012 | 04:04 PM
afpackard's Avatar
Default Flush signal install
i bought some flush blinkers for my cbr f4i its an 01 and im trying to find the best way to install them on my bike do i have to remove the fairing?
any help will be so appreciated.
Old Oct 29, 2012 | 05:29 PM
jeffjones's Avatar
Easiest way is to remove the front cowl, Gives you alot more room to work.
If you have girl hands and crimp connectors that require no cutting you might be able to get in there with just removing the side fairings.
Old Oct 29, 2012 | 06:16 PM
afpackard's Avatar
to take of the front cowl is that easy?
is this a quick install or is this something that will take a few hours?
i just want to make sure i do it right dont take short cuts and make sure i dont eff it up lol BTW thanks jeff for the reply
Old Oct 29, 2012 | 07:50 PM
RudyGT's Avatar
it's easy enough, you will need to unplug 2 harnesses while removing, remove your mirrors, remove the raim air covers and the bolts to the side fairings and the plastic V thing that has two pushpins at the top of the v thing that funnels air into the radiator mounted to the side fairings..
that's pretty much it, you may want a milk crate or a box to set it on while you unplug your harness, or two, i don't remember. when you reinstall it make sure your ram air snorkles fit into their slots it can be easy to overlook.
chris27house
Jun 2, 2012 11:31 AM
ks503
Jul 3, 2008 05:41 PM
fiveoh
Mar 20, 2008 03:42 PM
live2play
Feb 16, 2006 09:12 PM
