F4i won't fire
Old Mar 9, 2022 | 06:43 AM
Brandoscott513's Avatar
Default F4i won't fire
Cbr600f4i won't fire.. bike was running good until laid over on the clutch basket side and cracked the case and I repaired it until I buy a new one.. I've replaced pulse sensor. fuel pump primes. BAS bypassed clutch switch bypassed. It will turn over all day long but won't spark i've got 12v on one side of the ignition coil plugs but only 3 or 4v on the other? The diode in the ignition was blown but I took a 9v battery and hooked the pink wire to it to bypass it just to see if it would run and still won't fire.... Only thing I can think of is ECU PLEASE HELPPPPP!!!!!!
Old Mar 9, 2022 | 08:02 AM
74demon's Avatar
Could you have put the pulse sensor on backwards?
Old Mar 9, 2022 | 08:26 AM
I don't think I did hang on I'll send a picture of the way I installed it
Old Mar 9, 2022 | 08:44 AM
Is that not right?
Old Mar 9, 2022 | 09:42 AM
74demon's Avatar
That looks right. Did anything with the exciter ring get bent or damaged? Are all your grounds good? I think there is a ground on the left neck of the frame that needs to be there.
Old Mar 9, 2022 | 11:05 AM
When you say Exciter ring are you talking about the star like gear I guess you'd call it that the sensor reads? Btw thanks for the help
Old Mar 9, 2022 | 01:59 PM
74demon's Avatar
Yes. The sensor and ring need to be lined up to work.
Old Mar 9, 2022 | 03:19 PM
Doc Samson's Avatar
Originally Posted by 74demon
... the exciter ring...
Whoa, whoa, whoa! You mean I've owned my bike all this time and not known it had an "exciter ring"??? Eh, probably for the best... lol.
Sorry for the highjack...
Old Mar 9, 2022 | 03:43 PM
Do you possibly have a pic of the ring just to make sure we are on the same page
Old Mar 11, 2022 | 04:29 AM
Still need help..... anyone??😞
wot34
Jun 30, 2022 11:12 AM
Poptart99
Nov 15, 2018 02:29 AM
Pdalt1002
Jan 25, 2016 10:56 AM
BitRex
Sep 13, 2014 09:30 PM
Stunt'n70f4i
Oct 1, 2010 10:53 AM
