2002 Cbr f4i won't fire
Old Jan 3, 2016 | 08:00 AM
Pdalt1002's Avatar
Default 2002 Cbr f4i won't fire
I've read basically every thread on similar problems. I'm hoping someone has SOME type of insight on where to look next. So I got this bike off a trade. I knew that it didn't start. Kid said his brother used his battery and then when he put it back the bike wouldn't start. I thought it was an insufficient battery but it's showing well over 10.8 while cranking, more in the 11 or 12 range. The bike cranks and cranks but doesn't fire. The fuel pump primes, I put new fuel in it. Pulled and replaced all the spark plugs, grounded them on the head and they aren't getting spark. I don't have a "peak voltage adapter" like the service manual says but with the key on the inside of the coils are getting 12. I checked the pink wire in the harness up front, it was within spec. My kill switch is obviously working cause my bike won't crank when it's turned off. The bike is throwing an error code 19. Which is the ignition pulse generator. I replaced it with a brand new one. Still nothing. Kick stand switch works as it should. Cranks with the kick stand up, doesn't crank with the kickstand down while in gear. The neutral light comes on while in neutral and cranks with the kickstand down. Should I trace the harness next or should I bite the bullet and pick up an ECU. Please ANYONE with ANY information is very much appreciated. Thank you in advance.
Old Jan 5, 2016 | 08:21 PM
Pdalt1002's Avatar
Someone, anyone PLEASE! I'm chasing my own tail here!
Old Jan 6, 2016 | 04:19 AM
Mattson's Avatar
Umm... just to throw an idea, is there a bank angle sensor on you bike? A.k.a. the tipover switch. Dunno would it allow the pump to prime if it's triggered though... not familiar with the model and not a whole lot of f41:ists around these days...
Old Jan 6, 2016 | 07:32 AM
Pdalt1002's Avatar
Thank you for the insight. there is a bank angle sensor, im not sure if it would prime if it was faulty/triggered. Ill have to look into how to bypass it i supposed but its facing the right way so Im not sure how to tell if its triggered on or not.
Old Jan 6, 2016 | 05:56 PM
74demon's Avatar
Correct. The pump will not prime if it's faulty.
I'd be looking at the IPG exciter ring next.
Old Jan 7, 2016 | 09:54 AM
Pdalt1002's Avatar
ill have to google what the ignition pulse generator exciter ring is. I have the service manual and after replacing the IPG sensor, (cause it was throwing the code 19; faulty ignition pulse generator) it doesnt say where to go from there. any insight on the IPG exciter ring? I really appreciate the help
Old Jan 7, 2016 | 09:08 PM
74demon's Avatar
Its the ring inside that the IPG picks up when the motor is turning.
Old Jan 8, 2016 | 06:40 AM
Pdalt1002's Avatar
Ok; I'll replace that next. Is it common for that to to bad? It's just a piece of metal
Old Jan 11, 2016 | 08:51 AM
74demon's Avatar
No, its not a common thing to go bad. Just check it to make sure it didn't get damaged somehow.
Old Jan 25, 2016 | 10:00 AM
Pdalt1002's Avatar
Does Anybody think it would be the ECU? since i replaced the faulty IPG? im going to get the ring next. If i replace the ECU does it have to be year specific or just any f4i between 01-06?
