F4i taillight wiring
Old Nov 17, 2023 | 12:43 AM
dannoxyz's Avatar
Heh, that's making progress salvaging dead bike! They are such good bikes, many destroyed through neglect. Sad really, so glad you're bringing it back!
Starter circuit is completely separate from EFI system. So you can remove ECU, relays, pump, injectors, ignition-coils, plugs, etc. and starter will crank engine merrily all day long.
Ok, if ECU won't prime pump, it won't fire injectors or sparks either, so you'll want to start as high upstream as possible. Start at beginning of my guide with battery and go from there. Most likely you'll find problem in first couple steps with one of relays not working properly or ECU sensing fault-condition and not activating relays. That's typically where power-flow to pump and injectors stops.
Old Nov 17, 2023 | 09:26 AM
Yea, what he said.
Old Nov 17, 2023 | 11:04 PM
CAN-f4i's Avatar
Thank you for this. I ran the pump direct to battery and still nothing. So im going to order a pump and likely still have to trace the issues back to get it running.
Old Nov 22, 2023 | 07:16 PM
CAN-f4i's Avatar
I should have started with the pump 🤦‍♂️… ordered a new one and it started up right away!!! 🥳
Old Nov 23, 2023 | 08:07 AM
Scott91370's Avatar
That happens. Start at one end of the issue ad it's always onthe other.
Glad it running, now we ned some pics!
Old Nov 23, 2023 | 05:35 PM
dannoxyz's Avatar
Woohoo good job!!
Old Nov 23, 2023 | 10:35 PM
CAN-f4i's Avatar
Now that i knownit runs its getting stripped for paint and ordering parts 😂
obrienb
Jul 14, 2022 12:44 AM
NuggyBuggyCBR
Jul 12, 2022 09:27 PM
Christo Christo
Nov 8, 2020 04:00 PM
Stunt'n70f4i
Sep 6, 2010 10:52 AM
F4itanner
Jul 28, 2007 08:06 PM
