I have custom E85 maps...
Old Jul 20, 2008 | 12:16 AM
Mstngdrew232's Avatar
Default I have custom E85 maps...
I am creating custom E85 maps based off of a map from FuelMoto that is for a F4i with a hindle high mount slip on and a K&N air filter. I currently have maps for a 50/50 ethanol/regular mix, one for a 70% ethanol(winter) mix, and a straight E85 map.
I am currently testing the 70% ethanol blend map and i'm fine tuning things, the 50/50 mix tune is working very well for me, I have not used the full E85 tune yet.
I am by no means a professional tuner, all I'm doing is adding the necessary fuel increases for running E85 ontop of somebody else's tune. If you are interested or want to know more, please PM me or post up.
Old Jul 20, 2008 | 03:35 PM
65ShelbyClone's Avatar
Default RE: I have custom E85 maps...
Are you doing this on stock injectors? How is the AFR monitored?
Old Jul 21, 2008 | 01:14 AM
Yes, I'm doing on the stock injectors, I haven't seen a duty cycle over 59. I'm doing road testing and I'm reading the plugs to check the AFR, its not exact, but it works for safety. If I had the money I would buy a wideband commander and a LCD screen to datalog everything.
Old Nov 29, 2023 | 10:04 AM
Yendry's Avatar
Default Hola
Originally Posted by Mstngdrew232
Estoy creando mapas E85 personalizados basados ​​en un mapa de FuelMoto que es para un F4i con un montaje trasero alto deslizante y un filtro de aire K&N. Actualmente tengo mapas para una mezcla regular/etanol 50/50, uno para una mezcla de etanol al 70% (invierno) y un mapa puro E85.
Actualmente estoy probando el mapa de mezcla de etanol al 70 % y estoy afinando las cosas, el ajuste de mezcla 50/50 está funcionando muy bien para mí, todavía no he usado el ajuste E85 completo.
De ninguna manera soy un sintonizador profesional, todo lo que hago es agregar los aumentos de combustible necesarios para hacer funcionar el E85 sobre la melodía de otra persona. Si está interesado o quiere saber más, envíeme un mensaje privado o publíquelo.
Hola estoy interesado en el mapa, como puedo contarle
Old Nov 29, 2023 | 11:59 AM
Scott91370's Avatar
Mstngdrew232 hasn't been around since
  • Last Activity: 09-27-2008 01:32 PM
jimd2p
May 13, 2009 11:15 PM
cmmoist
Jul 27, 2007 09:23 PM
christhek
Apr 15, 2007 11:49 AM
ampakes
Dec 29, 2005 04:09 AM
