f4i odometer correction
Old Aug 15, 2010 | 01:52 PM
speedymike136's Avatar
Default f4i odometer correction
i layed down my bike a while back and im finally getting it back together. When i crashed it it had 4,5xx miles on it. If i buy a new cluster, assuming i can find one, it will have 0 miles on it and all of the used ones i find have 14000 or more. My question is can i somehow have it matched up to actual miles on bike somehow?
Old Aug 15, 2010 | 03:23 PM
exodus191's Avatar
If the cluster is at O miles and you want to roll it fwd to match the bikes actual mileage then yes that can be done. i had a link with a howto lemme see if i can find it..................
Old Aug 15, 2010 | 07:36 PM
ok thanks
Old Aug 16, 2010 | 09:04 AM
Sick97SS's Avatar
Highly doubt you will find a NEW cluster. Just keep searching ebay to find one with similar miles to what you have. I just saw one a few weeks ago that had 4000 miles.
They're a few places where you can send out your cluster to be re-programed with the correct mileage. But it's much easier just to find one on ebay/craigslist.
http://www.bluegauges.com/mileages.htm
Old Oct 17, 2010 | 08:47 AM
exodus191's Avatar
Sorry guy i totally forgot about this thread heres the link i was talking about
http://www.omninate.com/cbr600f3/
Click on modification and scroll down page a bit
Old Oct 17, 2010 | 09:24 AM
Kuroshio's Avatar
You can get one brand new from http://www.servicehonda.com. Price runs $400 for just the speedo / gauges or $469 for the gauges + case
Old Oct 17, 2010 | 10:02 AM
joeroberts's Avatar
What part of your speedo is Broke?
If it is just the housing then you can replace that with a new/used one and keep your system.
Or just replace what is Broke.
Mine had the lence broke and i replaced that from one that had the read out screen broke on it.
I took a look at the main board and it dont look to hard to replace most the parts on it If your any good with a soldering iron.
Old Oct 17, 2010 | 03:05 PM
Zero1080's Avatar
^I think he means the board/brains. I just need to replace the rear case on mine. No temp gauge or shift lift, but I know how my bike works. :P
Not to jack, but will the fan still work? I mean, the LED's even light up on the temp gauge, just cracked the screen so there's no numbers.
Old Oct 17, 2010 | 08:42 PM
joeroberts's Avatar
If the main board is not broke or cracked you can replace the peaces on it as I said
the main board is where all the memory is and if you can just replace the read out display then your readouts well remain in tacked.
Every thing well stell work as it should it is only a display nothing to do with the controls.
rino
Jun 12, 2009 06:17 AM
Bassman
Jul 8, 2008 12:40 PM
dakinemotoman
Feb 19, 2008 10:36 PM
Dean0
Nov 29, 2006 06:02 PM
cbrwrx
Jun 14, 2005 04:01 PM
