Speedo correction
Old Jul 7, 2008 | 02:29 PM
Bassman's Avatar
Default Speedo correction
I've noted that several board members have changed their final drive ratio. My '93 speedo drive is taken off the primary sprocket. Any change in ratios will change my speedo's calibration.
Have any of you found how to change the speedo drive to compensate for the sprocket change?
Old Jul 7, 2008 | 10:38 PM
Shadow's Avatar
Default RE: Speedo correction
As far as I know you can't........
Old Jul 7, 2008 | 11:11 PM
tallenuf's Avatar
Hey Shadow, If I recall correctly you said you dropped down two teeth on your front sproket? I assume you left the rear sproket unchanged. What sort of percentage change in the speedo reading do you now see from stock gearing?
Old Jul 8, 2008 | 12:45 AM
Shadow's Avatar
Around 12% over, and given that our speedo's are 10% over to start, the speedo becomes a bit of a time-waster. I've taken it back to stock at 17/42 now, too much stress on the chain, sprockets, my wallet, and my nerves - damned thing becomes a wheely machine !
HARDCORP runs a 14/46 ratio when he wants to outrun the GSX100R's off the line- and does !!
Old Jul 8, 2008 | 05:37 AM
Trips's Avatar
Yes it is possible to alter your speedo.
Go to an instrument place and you can buy a speedo gearbox that plugs inbetween the end of your cable and the speedo. Inside the gearbox is 2 teethed gears that are available in difference sizes etc. 90% 95% 105 % 110% etc.
I purchase them from VDO for trucks so I dont see why you cant get one for bike cables. However they are bulky so space may be a problem.
Old Jul 8, 2008 | 06:29 AM
GILL's Avatar
Not this topic again.....do a search on this and you will find scores and scores of information on speedo alterations for the Hurricane. Nothing persoanl, just trying to save you guys some time.....Heres a few
https://cbrforum.com/m_137320/tm.htm
https://cbrforum.com/m_274039/tm.htm
https://cbrforum.com/m_342709/tm.htm
Old Jul 8, 2008 | 07:29 AM
Shadow's Avatar
Oi ! You from the "Colonies" - your chain arrived yet ? he he
Old Jul 8, 2008 | 12:40 PM
Bassman's Avatar
Thanks for all the replies. You've confirmed whay I suspected. And Gill, I did a search. Perhaps I didn't use the right search term but all I got was the fix for the electronic speedos.
speedymike136
Oct 17, 2010 08:42 PM
EMILL
Sep 1, 2009 10:29 AM
dakinemotoman
Feb 19, 2008 10:36 PM
Dean0
Nov 29, 2006 06:02 PM
cbrwrx
Jun 14, 2005 04:01 PM
