F4I I need help
Old Feb 23, 2017 | 01:31 PM
cornflakesk's Avatar
Default F4I I need help
OK so I bought this stunt bike with a bad engine, took it all apart got new engine and got it running nice. my wiring harness was kind of cut up and some sensors like the bank sensor and the kick stand sensors were bypasses before hand. So i removed the main harness and re-taped the whole thing so it would look nice. I put it all back together and now when i turn the key no fuel prime. It was working perfect before hand but not its not and all i did was re tape the harness and replaced the connector that goes from the starter to the relay. Ive checked all the connections and i have it all plugged in right. I used jumper cables to the fuel pump and it works, so i kno its an electrical issue. any ideas?
Old Feb 23, 2017 | 01:54 PM
74demon's Avatar
Check the bank sensor connection.
Old Feb 23, 2017 | 06:55 PM
how would i check that? like making sure its still bypassed right?
Old Mar 2, 2017 | 08:12 PM
ShtBiker's Avatar
One of the big grey connectors that goes to the front fairing is required for the fuel pump to work. If I remember right when I put my bike back together, there is a second plug of the same size you can get mixed and plug each to the wrong one. You might want to look around for similar plugs that could have gotten reversed.
dr.squid
Jan 28, 2018 04:42 AM
2UpStunter
Oct 11, 2008 09:13 PM
jarhead89x
Sep 26, 2008 09:38 AM
mattyggstick
Jun 20, 2008 09:22 AM
the greeen lantern
Jul 13, 2007 09:19 AM
