F4I air filter
Old Mar 17, 2005 | 04:24 PM
dpenuell's Avatar
Default F4I air filter
I'm replacing my original air filter on my F4I with a K&N. How do you get the old filter out of the housing? Do you use the housing or do you discard it? I would think that you would have to keep the housing because of the fins that direct the airflow into the throttle body.
Old Mar 22, 2005 | 10:32 PM
ghosti25's Avatar
Default RE: F4I air filter
I when i replaced my filter, i just discared the old air filter, and directly placed the k&n in. I did not use anything from the old air fiter, the housing would not fit over the k&n.
Old Mar 24, 2005 | 11:52 PM
homer319's Avatar
I just found out that the filter is under the gas tank. How hard is it to get to it and how hard is it to change out. I would just like to know what I am looking at before I start surgery.
Old Mar 27, 2005 | 03:16 PM
syco_killar's Avatar
dude not hard what so ever, all you need to watch out for is there is a little hose on the right side of the fuel tank that will become disconnected when you lift the fuel tank, just remove your rear brake reservoir so you can get your hand up in there to reconnect it, other then that all the plastic you need to romove is a walk in the park. to put in short , a trained monkey can handle it.
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
