Engine stops when I switch on the headlights
Old May 16, 2020 | 01:56 PM
SkyRover's Avatar
I hope I found out where the problem was.
I believe it is something related to the MAP sensor or the hose itself connected to the map sensor. It appeared that the MAP sensor was loose and not attached with a screw as the hole for the screw was damaged and the sensor was loose.
Regards,
Old May 18, 2020 | 03:58 PM
boredandstroked's Avatar
That shouldn't have anything to do with the headlights. Map sensor reads via the vaccum hose attached to it, if the vaccum hose was still attached it was working properly.
chazgriff
Nov 26, 2019 02:12 PM
scudster
Feb 19, 2017 12:16 PM
clj016
Jun 15, 2011 07:47 PM
Zen Rider
May 10, 2011 12:35 AM
mah929
Aug 28, 2005 10:17 AM
