Engine noise
Engine noise
I just recently purchased an 03 F4i. I've noticed during decel that i'm getting a ticking noise that sounds like the timing chain. After doing a little research I discovered the CCT problem and was wondering if this sounded like anything anyone else had experienced. I've also noticed alot of play in the drive line when switching gears or going from decelerating to accelerating. I adjusted my chain which seemed to help but didnt eliminate the problem. Wondering if this could be slack in the time chain possibly? Any insight is appreciated. Thanks
If it jerks forward you might need to work on shifting and clutch control a bit...when I have just been lazy with shifting,the bike will jerk when you dont all the way let off the throttle between shifts. Also might be letting the clutch out to slow and getting on the throttle too soon resulting in a "jerk" feeling
