Electrical Issue, Need some help..
Old Aug 1, 2008 | 04:45 PM
sig239's Avatar
Default Electrical Issue, Need some help..
Sup all,
So last night I went out for a ride and everything is normal. Go out this morning for a ride and both turn signal indicators are staying on, all signal lights are also lit but very dim. The wierd thing is when you go to signal, it instantly stalls. If no signals are used it runs just fine. Also the low beam headlight is on but very dim also, high beam will not come on at all. I have checked all fuses and nothing has happened since it was running fine to explain this. If someone could help me out here I would really appreciate it, thanks.
Old Aug 1, 2008 | 05:21 PM
bluej511's Avatar
Default RE: Electrical Issue, Need some help..
Id say check connections, if you have aftermarket turn signals id check those first. Then i believe the green wire/pin inside the bulk connector up front is known to cause problems.
Old Aug 1, 2008 | 06:27 PM
ampfp's Avatar
that's probly the ground pin in the headlight connector...
Old Aug 2, 2008 | 03:00 PM
sig239's Avatar
Could you describe a little more where this green wire/pin in located? Thanks
Old Aug 2, 2008 | 03:07 PM
bluej511's Avatar
Its the big bulk connector behind the headlights, just look for the green wire, unplug the connector make sure its not corroded or loose. Apply some di-electric grease and plug it back in.
Old Aug 2, 2008 | 07:19 PM
mycvil's Avatar
See:
https://cbrforum.com/m_520431/tm.htm
Had the exact same problem - but mine was a bit more violent - bike just shut off - no headlights - etc. I ran a ground wire from the headlight harness - Green wire-directly to the fan ground- You'll see it on the left - seems to have cured my problem.
Wish this site would work correctly...
Old Aug 3, 2008 | 12:02 AM
sig239's Avatar
^^^ dude, thank you so much...problem is fixed. That would of taken forever to find something so simple. Checked out the plug and it had melted at the ground pin. Just by-pased the whole plug for the ground and everything is back to normal. Thanks again!
Old Aug 3, 2008 | 09:32 AM
mycvil's Avatar
Do you havestock lights/turn signals - No high wattage bulbs, original turn signals? - Mine were swapped for incandescent flushmounts - Not sure if that is enough extra draw to melt the harness or what - I should write up a complaint on NHTSA on this issue - seems to be a major safety concern (Bike stalls for no good reason suddenly).
Glad to hear everythings' working as it should be! - ENJOY!
Old Aug 3, 2008 | 04:29 PM
sig239's Avatar
I have some universal turn signals, same watt bulbs as factory I believe and silverstar headlights. Only thing I can think of is I always ride with my brights on..who knows. Thanks again though man.
Old Aug 3, 2008 | 11:12 PM
Jaybird180's Avatar
I noticed that riding with the brights on was consistent between your two senarios. Wiring is rated for certain wattages. Brights draw more and therefore produce more heat. The wiring can only dissipate it at a certain rate. If we can confirm the brights as the issue (as it would seem to be) then we have a solid case for using low beams only (which I do).
dvslaz
Jul 25, 2011 11:07 AM
turbotrix
Jul 4, 2011 12:42 PM
j.stursma
Sep 30, 2009 09:48 PM
Shamous
Sep 18, 2009 09:09 PM
3dgar RR
Nov 5, 2008 05:20 PM
