Dropped my bike this morning (!!!!!!)
Old Nov 27, 2010 | 08:58 PM
  #101
mbison83's Avatar
Task within a task..............
F**kin A!
Thanks for the info, friends.
Old Nov 29, 2010 | 02:00 PM
  #102
mbison83's Avatar
the studs on the f4i's manifold are too short for this. i guess im gonna need to take it to a shop.
Old Nov 29, 2010 | 03:05 PM
  #103
Ragnar1x's Avatar
If you have the manifold out on a table you probably don't need to leave enough space for the wrench to swing freely between the manifold and the nut. If you can thread two nuts on there, that should be all the room you need. You may not even need the box end of the wrench. Just try threading the nuts all the way up and using the open end of the wrench.
Old Nov 30, 2010 | 06:34 PM
  #104
mbison83's Avatar
thanks. took it to a shop and they did it for $10. these suckers started coming off after i've fitted the nuts on them. i mean, what the hell??
Old Nov 30, 2010 | 08:21 PM
  #105
breethwithme's Avatar
you should download a manuel to help you there is some good free ones out there.but i only know one for the 900rr not the 600 sorry
Old Nov 30, 2010 | 11:24 PM
  #106
mbison83's Avatar
i have the service manual for my f4i (the book).
Old Dec 2, 2010 | 01:08 AM
  #107
mbison83's Avatar
are the valve clearance and cam positioning the only things I need to check before getting the head bolted down?
Old Dec 2, 2010 | 11:21 AM
  #108
jp_greenville13's Avatar
check for warpage in at least 8 differant spots with a straightedge on the head and the block
Old Dec 2, 2010 | 12:05 PM
  #109
mbison83's Avatar
What spots do you have in mind, and whats a straightedge?
Old Dec 2, 2010 | 05:06 PM
  #110
Staightedge: Any thing that you can be sure is a true straight edge (a t-square, the metal edge of a wooden rule ect.)
Check across, lengthwise and diagnally. your straightegde should be flush with the surface in every direction.
