Dropped my bike this morning (!!!!!!)
#51
Yesterday I've removed the fairings, tank, air box, radiator, cylinder head cover and drained the oil. When I've attempted to drain the coolant (with the use of the manual), practically nothing came out. It seems there was no coolant in the reservoir. Anyway, I'm pretty sure I can do this without dropping the engine. Just waiting for the head to come in mail so I could get the swapping done and get back on the road. Good thing is that I will do the oil (amsoil synthetic) & coolant change, spark plug (ngk iridium) and air filter (k&n) replacement while I'm at it.
#52
If those sliders did this with a static drop, they'd have trashed the entire engine in a highspeed get off. Probably be better with no sliders.
#56
Update: So I'm stuck on removing the head now and am at the step in my service manual that says to remove the cctl bolt and washer, done. then to use a stopper tool. What the hell? Where can I get it at? I was not ready for this. Is it really with the necessary to mess with the cctl and removing the camshafts when swapping heads? Whats the easiest way to do this? I NEED YOUR HELP.
#58
#59
the stopper tool is a piece of metal used to hold the lifter 'max in' position. use a small flathead screw driver and turn it clockwise inside the tensioner to relieve pressure on the chain guide. this allows you to take off the CCT without damaging the threads for the 2 mounting bolts.
honestly tho just back out the 2 mounting bolts evenly and you will be fine. do you have the motor out of the bike? cause the first method i gave would be a PITA with the motor in the frame.
#60
