difficult to do?
Old Jul 13, 2007 | 08:09 AM
urandaman's Avatar
Default difficult to do?
when i bought my bike(02 f4i)the guy took off the ram air ducts, i have the pieces and was going to put em back on tomorrow if im not tooo hungover after tonight ha. but is it difficult to do? and do they just fit in place or are there any screws that hold them in?
im guessing the fairings will have to come off, but what about the gauge cluster? or headlight?
-side note- i have led flush mounts on their now.. stuck on with double stick tape, but they are starting to droop.. keep flush mounts or put stock ones back on, where people could actually see them haha.
Old Jul 13, 2007 | 08:24 AM
Tahoe SC's Avatar
Default RE: difficult to do?
the actual air tubes or just the plastic covers?
if the first you'll need to lift the tank to get to the air box. then it's still a pita getting the rubber back into the air box with the right grooves...if it's the latter, then no.
use sticker stuff for your flush mounts.
Old Jul 13, 2007 | 08:28 AM
urandaman's Avatar
its the tubes that run from the "vents" up front right next to the forks. not the whole section (the tubes on there end about 1" infront of the gas tank
Old Jul 13, 2007 | 09:02 AM
Streetdemon's Avatar
I ♥ CBRF
No screw required they fit in place. The resonator will hook up to a metal harness hanging off of yourupperstay...Piece of cake. I had to do my left side after a spill and I dont think I removed any of the fairings.One note to make things easier:Put your bike in the sun for a few minutes. Itsmuch easier to install once the rubber tubes expand.
Old Jul 13, 2007 | 09:05 AM
urandaman's Avatar
thanks for the tip!
ill prob take off the fairings and clean em up a bit and see if there are any loose wires... might as well put the frame sliders on then hah.
Old Jul 13, 2007 | 09:20 AM
I ♥ CBRF
Good call !! Next time I pull mine off I'm finally going to put my sliders on to.
Old Jul 13, 2007 | 09:47 AM
urandaman's Avatar
now i just have to convince my neighbor to let me use his rear bike stand and hope his front stand works since his race bike has no side stand ha.
Old Jul 13, 2007 | 04:53 PM
ampfp's Avatar
you dont need the stand... granted it's a little harder without it, but not necessary
Old Jul 13, 2007 | 06:27 PM
urandaman's Avatar
i like things easy. i will probally end up doing all the work down at my neighbors house since he actually has space to work on the bikes in the garae unlink my house with loads of crap piled up ha
cbrpaul
May 9, 2015 11:38 AM
KLO
North East
Feb 24, 2009 09:20 PM
SevenT6Vet
Jan 11, 2007 10:50 AM
vtalin
Jul 28, 2005 04:09 AM
Amanda
Mar 1, 2005 11:11 PM
