Different NGK spark plugs
Old Aug 14, 2006 | 08:19 PM
jorge13's Avatar
Default Different NGK spark plugs
I bought several days ago a set of NGK IMR9C-9H, instead I received the IMR9A-9H.
Are they similar? Can I use them without problem ?
Old Aug 14, 2006 | 08:24 PM
Tahoe SC's Avatar
Default RE: Different NGK spark plugs
check it mang...i don't think so...
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Old Aug 14, 2006 | 10:33 PM
jorge13's Avatar
Hi Tahoe ! You always so helpfull !
I think that different codes are different codes for something and my manual says IMR9C-9H so I don´t want to take the risk and use something " similar".
I´m thinking that maybe old models use the 9A and there is the mistake.
I will wait the correct ones, don´t you think ?
cheers
Old Aug 15, 2006 | 04:19 AM
jorge13's Avatar
http://www.ronayers.com/browseparts....ng=98059-5991U
Strange, the 9A costs 21 against 14 the 9C.( original one )
By the way the 9C means tangencial ground electrode
Cheers
Old Aug 15, 2006 | 01:51 PM
Tahoe SC's Avatar
yea that pdf i athached from NGK calls 9C a low angle ground electrode, and 9A special design...whatever that may be.
i've never tried the 9A before, just the 9C as well as platinum equivalent...no noticeable difference whatsoever, just plats cheaper.
Old Aug 16, 2006 | 01:22 AM
jorge13's Avatar
How many miles life can you expect from these spark plugs, Tahoe ?
cheers
Old Aug 16, 2006 | 09:27 PM
Tahoe SC's Avatar
i usually replace mines at 8K, but at 8K they look fine, i just do it because i'm there doing other stuff anyway.
i had about 12K one one set and they were still in spec and fine.
Old Aug 18, 2006 | 03:08 AM
jorge13's Avatar
So..........I will wait a little to change it!
Old Aug 18, 2006 | 04:31 AM
JVracer04's Avatar
the 9C's come in the 600RRs
several ppl "upgrade" to the 9c's for their F4i's and claim noticable differences, but its all bullcrap. Unless u constantly use octane booster on top of 93 octane fuel or have major engine upgrades that need stronger supporting systems(fuel and spark) then you dont really need them, nor will u notice a difference
I just replaced my spark plugs with the normal 9A's and it turns out the previous owner of the bike had the 9C's in there... I havent noticed a slightest difference
Old Mar 5, 2007 | 03:18 PM
Jaybird180's Avatar
ORIGINAL: Tahoe SC
So you'd recommend going with the Platinum for cost savings and get same performance. Just change them out 8-12k. Isn't that about the normal life of an Iridium for a sportbike?
baseballkid
Oct 4, 2012 07:48 AM
jvhjgh2006
Jun 26, 2011 02:07 AM
Carbon_cavvy
Feb 29, 2008 08:25 PM
eukanuba517
Feb 19, 2008 04:54 PM
mikey1297
Jul 11, 2006 02:42 PM
