Cranks but no start
I was doing my flush mounted turn signals, i have the hole front head off (headlight assembly) and finally converted 3 wire to 2 wire. I only have 1 signal done. Well i noticed that when i turn the key to the on, the whine doesn't come from the fuel pump turning on like it used to. When i try to start it the bike just cranks and no start. I have the connector plugged in (the big block one that goes from the front end to the dash i assume)
I checked the fuse box right next to the battery and all the fuses in there were ok. Everything works, the dash comes on signals, brakes. Is there another fuse box for fuel pump or injectors or something?
I didn't touch anything else. just been messing with the wires for the turn signals (i was trying to wire it to work without a resistor but eventually went and got the resistor)
What can i do to troubleshoot why it won't start? It started perfectly fine yesterday. It is a 2002 cbr 600 f4i with delkevic exhaust, flush mount integrated rear signals, and attempting to put in the front signals but not done.
