Cooling issue
Old Mar 30, 2022 | 11:23 AM
macman756's Avatar
Default Cooling issue
Got a cooling issue on my 05 F4i. First, it idles too high. Like 3k. Then I let it sit and idle in the driveway to see and sure enough it overheated. Noticed the fan never came on. Fuse was good, so I jumped the radiator temp switch to ground and the fan worked just fine. As a temp fix, I jumped to ground so the fan runs as long as the key is on. Rode a bit and the temps are still high, 235° or so. Coolant is full, nothing is weeping from the water pump.
I have ordered a new radiator temp switch for the fan to switch on properly, but worried I could have a bad thermostat, water pump, blockage or wax unit. Any ideas?
Old Mar 30, 2022 | 12:53 PM
boredandstroked's Avatar
There is a manual idle speed adjuster. If that's not the issue, its either waxing unit or large vaccum leak.
As for cooling, I'd put a new thermo in and new coolant and see what happens. Bad water pumps are basically un-heard of. Radiator could be blocked from bad maintenance as well. 235* just sitting at 3k rpm doesn't sound off if thats what you meant though, but 235 while riding is getting high.
CSXfan
Jul 23, 2011 01:29 PM
schroncc
Aug 18, 2010 05:43 PM
ice05354
Jul 23, 2009 11:34 PM
bigjo
Sep 25, 2007 05:19 AM
Antsurf
May 25, 2007 10:32 AM
