coolant leak
Old Aug 22, 2011 | 08:29 PM
STRETCH15's Avatar
Default coolant leak
Ok guys for the past three times I been out rideing I ha e notice a slick spot on the ground when I park. So tonight I took the side fairing off and notice its dripping around the area of the water pump. I can squeeze the hose and it leaks does this mean I need a new pump or can the thermostat just be messed up. Bike don't over heat at all
Old Aug 23, 2011 | 10:30 AM
Xander F4i's Avatar
you said it leaks when you squeeze a hose...where is it leaking when you do that? the hose (if that's the case you need to replace the hose and/or tighten/replace any clamps that may not be holding at this point) or between to parts like the pump housing and the block (if this is the case, you may need to remove the pump and replace the gasket).
Old Aug 23, 2011 | 01:48 PM
Cheever's Avatar
Sounds like a bad coolant hose or clamp, did you try to tighten the clamp? If it's leaking around where the water pump meets the block, then you might need a new gasket. Any pics?
Old Aug 23, 2011 | 03:44 PM
STRETCH15's Avatar
It leaks from the pump when I squeeze the hose ill put pics up soon as I figure out how to on my phone
gump
Apr 9, 2011 10:00 PM
Ragnar1x
Apr 9, 2011 09:29 PM
dominiksi
Feb 7, 2009 12:17 PM
phamtastic0
Feb 5, 2008 02:21 PM
mattyg
Apr 26, 2007 02:58 PM
