Coolant change ques....
Old Apr 25, 2011 | 08:43 AM
Matt5606's Avatar
Unhappy Coolant change ques....
So i decided to change the coolant on the bike this weekend, and i followed the service manual for the bike. Now, it says to blip the throttle a couple times to remove the air from the system, which i've done. I've kept the rad cover off, as it says in the manual to remove all the air, however, the temp is getting up to 105 degrees celsius and the fan isn't turning on, and the coolant is bubbling and sometimes shooting out the filler neck. Anyone know what's going on??
Old Apr 25, 2011 | 09:41 AM
F34Me?'s Avatar
Could be a stuck thermostat. That or you didn't run it long enough for the thermostat to open. Take the radiator cover off, run the engine until you see the coolant circulating through the system then top it off and your problem should be solved!
Old Apr 25, 2011 | 09:58 AM
Syphen's Avatar
The F4i's fan doesn't kick on until 109 degrees C btw.
Old Apr 25, 2011 | 12:05 PM
Matt5606's Avatar
Yeah thanks guys, for some reason i thought last year the fan was kicking in somewhere just over 100 degrees celsius. If i had waited long enough, i would have found out it turned on around the 107 mark.
jamescbr87
F2 Tech
Jun 16, 2012 03:49 AM
live4liftin
F2 Tech
Mar 18, 2010 07:14 PM
Ride Red Bull
Jan 20, 2009 09:33 PM
rustler84
May 1, 2008 07:33 PM
9fiddyfo
Jan 20, 2006 10:56 PM
