clutch switch wires
Old Jun 26, 2010 | 05:13 PM
tyfrist's Avatar
Default clutch switch wires
well my clutch switch is bad so i was going to try and clean off the wires real quick and see if that fixes it...
question though... do the wires just pull straight out? or do i need to loosen the bolts that hold the clutch on and adjust it that way? i'm going out on a ride tonight so i don't want to just rip the wires out and screw it up...
thanks
Old Jun 26, 2010 | 09:02 PM
Sick97SS's Avatar
The two wires should just "pop" off the 2 terminals. They are just strait and flat "tab" style connectors.
Sometimes from being weathered the switch will stick. To take it out you DO have to remove the bolt and take off the clutch lever. no biggie though. then use a screw driver and push inward between the two prongs or tabs and the switch will fall out. take it apart and make sure it function properly.
macka_moose
Nov 10, 2012 02:56 AM
Bugkiller
The Hurricane Saloon
Jul 28, 2012 04:42 PM
Slydell19
Jul 16, 2010 07:18 PM
trishcbr
Jul 17, 2007 02:36 PM
mymateaid
Jun 21, 2007 03:55 PM
