What does the switch on the clutch lever do?
Old Apr 26, 2009 | 05:52 AM
macka_moose's Avatar
Question What does the switch on the clutch lever do?
Hi, probably a daft question - but there is a switch on the clutch lever, What does it do?
Problem we have is that we removed the ECU as a security measure when the CBR600 F was off road, now its back in the bike starts and runs just fine but when you put in gear and let the clutch out the engine stops.
Disconnected the wires to the switch and shorted them out and it works OK, so whats the switch for, and why s it turning the engine off?
Old Apr 26, 2009 | 06:39 AM
Rod38um's Avatar
Not really sure from a mechanical point of view but as I let my clutch out, that switch connects and ups the idle just a bit right b4 the clutch takes hold. I think it just preps the fuel mixture to go from idle to a load on the engine or to aid in taking off without stalling..... not sure of the intent.........
Old Apr 26, 2009 | 06:54 AM
PlayfulGod's Avatar
mm no lol, its a safety switch thats works along with the kickstand safety switch. If the kickstand is down its switch wont allow the bike to start at all with the bike in gear or 'without' the clutch being pulled in, hence its lil switch.
Old Apr 26, 2009 | 07:00 AM
Thanks for that info, the stand switch works fine. In gear, engine running flip the stand down and the engine is cut.
I wonder why that clutch lever switch kills the engine when I try to move off. Definitely that, shorted the switch out and it all works fine.
I wonder if something got reset in the ECU when it was disconnected for so long,
Any one any ideas?
Old Apr 26, 2009 | 07:18 AM
PlayfulGod's Avatar
Any one any ideas?
kickstand up when you do it?
Old Apr 26, 2009 | 12:14 PM
justasquid's Avatar
the clutch switch works in conjuction with your neutral safety switch. If the bike is in gear, you have to pull the clutch in for it to start. This prevents you from starting your bike in gear. The clutch switch overrides the neutral safety switch.
Im curious about that one too.
Old Apr 26, 2009 | 12:24 PM
Yep, kickstand is up.
Just go to pull away and as you let theclutch out the engine cuts out.
Shorted the switch out and bike runs and drives OK.
Very strange
Old Apr 26, 2009 | 12:25 PM
randyjoy's Avatar
Sounds like a bad switch
Old Jun 23, 2010 | 10:55 AM
Mr. Isy's Avatar
Where is the neutral safety switch located?
Old Aug 9, 2010 | 01:26 PM
Hondaondabrain's Avatar
Its inside, you can only see it when you take the lever off.
