What does the switch on the clutch lever do?
Hi, probably a daft question - but there is a switch on the clutch lever, What does it do?
Problem we have is that we removed the ECU as a security measure when the CBR600 F was off road, now its back in the bike starts and runs just fine but when you put in gear and let the clutch out the engine stops. Disconnected the wires to the switch and shorted them out and it works OK, so whats the switch for, and why s it turning the engine off? |
Not really sure from a mechanical point of view but as I let my clutch out, that switch connects and ups the idle just a bit right b4 the clutch takes hold. I think it just preps the fuel mixture to go from idle to a load on the engine or to aid in taking off without stalling..... not sure of the intent.........
Originally Posted by Rod38um
(Post 776058)
Thanks for that info, the stand switch works fine. In gear, engine running flip the stand down and the engine is cut.
I wonder why that clutch lever switch kills the engine when I try to move off. Definitely that, shorted the switch out and it all works fine. I wonder if something got reset in the ECU when it was disconnected for so long, Any one any ideas? |
Originally Posted by macka_moose
(Post 776063)
the clutch switch works in conjuction with your neutral safety switch. If the bike is in gear, you have to pull the clutch in for it to start. This prevents you from starting your bike in gear. The clutch switch overrides the neutral safety switch.
kickstand up when you do it? |
Yep, kickstand is up.
Just go to pull away and as you let theclutch out the engine cuts out. Shorted the switch out and bike runs and drives OK. Very strange |
Sounds like a bad switch
Where is the neutral safety switch located?
Its inside, you can only see it when you take the lever off.
