clutch Problem
Old 10-25-2009, 07:55 PM
skimb37's Avatar
Default clutch Problem
I have an 2001 f4i and i was riding today and pulled the clutch lever in and it stayed in and the bike would not disengage the gear (stayed in gear)? any help.. Do i need a new clutch?
Old 10-25-2009, 08:08 PM
Aken's Avatar
July 2008 ROTM
Sounds like your clutch cable broke. Does the clutch lever move around freely now with no resistance? If so, broken cable. It's like a $25 part IIRC, and very easy to replace yourself.
Old 10-25-2009, 08:29 PM
R Dub's Avatar
October 2011 ROTM
Clutch cable would be my first guess.
Old 10-25-2009, 08:53 PM
skimb37's Avatar
i'll check, thanks
Old 10-27-2009, 08:38 PM
skimb37's Avatar
Its not the clutch cable, it seems to be fine. any there things to check?
Old 10-28-2009, 10:16 AM
R Dub's Avatar
October 2011 ROTM
If the clutch lever on the crankcase moves when you pull the clutch in, I believe it is time to get your hands dirty. I think your next step is to take off the right crankcase over and inspect the clutch. Check the spring, friction disk, basket, ect for wear and/or broken pieces. Good luck
Old 10-28-2009, 07:25 PM
skimb37's Avatar
k, thanks
mlrtime99
10-10-2007 03:11 PM
smak_blaze
03-30-2007 05:40 PM
lowrinlife
07-30-2006 02:18 PM
lowrinlife
05-27-2006 12:18 PM
lowrinlife
05-26-2006 09:21 PM
Quick Reply: clutch Problem
