Clutch cable route
Old Jun 18, 2009 | 08:23 PM
DBEAU's Avatar
Default Clutch cable route
Quick question guys, I'm kinda hing up on the routing of cables up front.
Does the clutch cable go the outside or inside of the right fork?
And, the throttle cables go over the brake lever and brakes lines right?
Old Jun 18, 2009 | 10:14 PM
Aken's Avatar
July 2008 ROTM
Check attachment, holla.
Old Oct 29, 2013 | 09:47 AM
RudyGT's Avatar
inside, yes, yes.
my throttle cable is going under the brake lines though because i replaced it with 2 and they move up better that way.
when the brake lines are fixed to the lower tripple sure go above/around them because the brake line doesnt move at that point.
the picture is dead on.
here is a run down, the clutch cable runs behind the ignition and will be in your speedometer's face.
the metal part of the throttle cable, if it points up or down. no.. just no.. and brake lines we've covered.
Zandaloo
Aug 22, 2013 03:26 PM
fbpsb82
Jan 30, 2010 02:23 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
