clutch cable
Hey, im sorry but I know I can search this but my comp died and im using my phone and I can't get the earch feature work properly. The clutch cable adjustment is mucho far out and I still need tolessen the clutch play.... What do I do now? I know there is another adjustment method, but im unsure where it is
Are you talking about the lever part?
There is an adjuster on the Lever,
then there is an adjuster on the actual clutch cover on the trans.
You can adjust the two screws on the clutch over to tighten it
and you can pull the screw out on the lever (clip on) to tighten it.
if those are all the way out you should probably get a new clutch cable.
I have a brand new one in if you are interested
Zandaloo
Aug 22, 2013 03:26 PM
