clutch cable
Old Feb 28, 2010 | 07:47 PM
vangill's Avatar
July 2010 ROTM
Default clutch cable
my clutch is still slipping, ive tried 3 different oils, and still no luck, mineral oil has helped a ton compared to sythetic, made my bike run tons smoother than the rotella t synthetic. that was good stuff but i doubt ill run it again.
anyways, ive looked and looked and i cannot find this info, how much slack should be in my clutch cable? i think its too tight-there is no slack whatsoever but its adjusted all the way at both the clutch cover and lever, where else can i adjust it? also does anyone have pics of the clutch actuator arm-i am curious to see the angle of one that works properly compared to mine.
thank you for your help
Old Feb 28, 2010 | 07:54 PM
02f4irider's Avatar
maybe you need new plates
Old Feb 28, 2010 | 08:02 PM
vangill's Avatar
July 2010 ROTM
thats what im thinking i may need to do. i just wanna be sure of this one thing first before i get some and change them out. the clutch only has 10000 miles or so on it. so its not terribly old. ive heard heavier springs might fix it too.
i wanna make sure my cables not too tight first before i ask about springs tho
Old Feb 28, 2010 | 08:43 PM
02f4irider's Avatar
i would start with the plates i had trouble with mine last year it was slipping in 5th and 6th gear replaced the plates and i was good to go
Old Feb 28, 2010 | 08:51 PM
vangill's Avatar
July 2010 ROTM
aight, which ones did you put in? just out of curiousity. also did u slip in any other gears-i pretty much slip in any gear if i hammer on it hard after about 7-8000rpms, except first and second
Old Feb 28, 2010 | 09:16 PM
02f4irider's Avatar
ya your plates are fried then, and i got a set of oem friction plates from a friend for a hundo. but barnetts are good and there are a few other brands. the only problem you may have is some brands dont like synthetic oil, so it may be a trail and error with oil.
Zandaloo
Aug 22, 2013 03:26 PM
fbpsb82
Jan 30, 2010 02:23 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
