Cluster Resets
Old Feb 18, 2009 | 09:33 PM
pimpax56's Avatar
Default Cluster Resets
I know this is 2 threads at the same time but..i also have a problem with my cluster getting reset...everytime i shut the bike off my time and trip miles get reset to 1:00 AM and 0 miles...im sure the battery is still good so i dont know what the problem could be
Old Feb 18, 2009 | 11:12 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Hey Pimpax56, you're going to need a Service Manual. You can download one for free up in the General Tech area; it'll be a sticky on the top titled "manuals". You'll need a multimeter to check for continuity. It sounds to me that the wire(s) in charge of memory (clock/mileage) are/is disconnected.
In the future you may also want to specify the type/year of bike you have
Old Feb 19, 2009 | 08:27 PM
pimpax56's Avatar
2001 f4i...i have a service manual i dno where to find what you're talking about though
Old Feb 19, 2009 | 09:02 PM
Aken's Avatar
July 2008 ROTM
The gauge is supposed to have a positive charge going to it at all times, regardless if the bike is on or off. Look at the wiring diagram to find those wires (probably just positive and negative), then use a multimeter to see if the gauge is getting what it's supposed to. If not, you know what to fix.
Old Feb 19, 2009 | 10:24 PM
Incognito's Avatar
It's going to be page 19-11 ~ Power/Ground Line Inspection
Old Aug 18, 2009 | 09:41 AM
JasondanGraham's Avatar
I have the same bike with the same problem and was wondering what you found out, did you get the problem solved?
HondaRocks
Sep 12, 2008 04:13 AM
hoopster3
Mar 11, 2008 12:07 PM
james007torres24
Feb 19, 2007 12:40 AM
CBRF4i02
Oct 27, 2005 10:15 AM
