Cleaning it
Old Apr 12, 2006 | 12:50 AM
Stephens's Avatar
Default Cleaning it
I put on a protective tank cover, its a sticker with a plastic covering. I wanted to take it off. I took off the plastic and the sticker is still on the tank. I tried peeling it off, and it would'nt come off. Anyone have a suggestion how to get the sticker off without ruining the paint on the tank?
Old Apr 12, 2006 | 12:58 AM
DThompson's Avatar
Default RE: Cleaning it
use really hot water and a rag, thats all I ever use when Im taking sticker glue off of things.
Old Apr 12, 2006 | 03:44 AM
F4iGuy33's Avatar
Im not sure if this will do anything to your paint but i know that like if your trying to get a sticker off of a window or something goo gone works good.
Old Apr 12, 2006 | 03:46 AM
Icefox's Avatar
You can try Goof Off too, I'd test it in an area that wouldn't show up too well in case it dulled the paint first before I put it on my tank, but I have friends that use it to debadge thier cars, remove stickers, and today I saw it used to remove paint marker from a fuel tank on a bike and it didn't hurt the paint on that bike.
Old Apr 12, 2006 | 04:42 AM
shraz's Avatar
spray some WD40
and blow dryer
Old Apr 12, 2006 | 03:45 PM
stinger95's Avatar
Another vote for Goo Gone. I wouls stay away from Goof Off, that stuff is nasty!
Old Apr 12, 2006 | 03:58 PM
Leveltwo's Avatar
goo gone seems to dull the paint if used too hard or rough. use it sparingly and dont get in a hurry and you should be fine, try setting the bike out in the sun for a while, to heat up the sticky goo, then dab goo gone with a non-abraisive towel, and try to pick at it with your fingers, if you have a few scratches when finished, a good wax should buff them out fine.
Old Apr 14, 2006 | 04:36 PM
Stephens's Avatar
Sounds like goo gone is the answer. thanks for the advice
Old Apr 16, 2006 | 07:38 AM
snobrdrdan's Avatar
ORIGINAL: Leveltwo
x2
If you have to use a adhesive remover....like goo gone or goof off, they tend to make the paint dull if you rub too hard.
After you are done, a coat of wax brings the shine right back though.
Basically, just be careful using it.
Hyperblau
Feb 21, 2012 06:29 PM
pahurricane
Apr 10, 2008 08:41 AM
Apocolypse
Apr 4, 2008 12:04 PM
madmike01uk
Jun 4, 2007 10:19 PM
907hondaf3
Mar 24, 2006 02:26 AM
