Changing Clutch
Old Dec 22, 2009 | 04:16 PM
caddylicious's Avatar
Default Changing Clutch
So i picked up a pair of pazzos, brake lever was super easy to change, on the clutch lever i can't get the wire back in the new lever, anyone know how?
Old Dec 22, 2009 | 04:28 PM
vangill's Avatar
July 2010 ROTM
if you got a buddy have him engage the clutch using the lever down on top of the clutch cover. that could help. also make sure you got the adjuster all the way in so you have some slack in the cable.- im sure youve already dont that but i just wanted to throw it in just in case
Old Dec 22, 2009 | 10:01 PM
ID_CBRRider's Avatar
If you put new levers on you want to check your adjustment anyways. So to make it easy just adjust your cable all the way out to put the lever's on. Then readjust your cable and ride.
On a side note I have Pazzo's also. I only picked them up because they were hella cheap on CL but since I did I won't own another bike without nice levers...They are so comfortable to ride with.
Old Dec 23, 2009 | 03:23 AM
I know! I love pazzos! how do i adjust the cable to make it come all the way out?
Old Dec 23, 2009 | 04:38 PM
The short version is to loosen the nut on the cable by the lever. If that doesn't give you enough slack, then you losen the nuts where the cable goes into the clutch housing on the right side of the bike.
You might need to check your service manual for more details, I can't seem to find my service manual I had on my computer to give you a more detailed description.
Old Dec 24, 2009 | 11:00 PM
k thanks ill go look!
Old Dec 25, 2009 | 05:02 PM
lil_schmitty01's Avatar
did you get it to work? should be able to connect the wire before you fasten the lever to the bar. should be pretty simple if attached before.
bundy26
Feb 28, 2011 06:30 AM
Ward32188
Mar 12, 2008 08:53 AM
Ward32188
Mar 11, 2008 06:19 PM
Ar15 guy
Mar 20, 2007 06:38 PM
Ar15 guy
Mar 14, 2007 08:29 PM
