Chain & Sprocket
Old May 1, 2009 | 01:17 AM
nakedcivic's Avatar
Default Chain & Sprocket
i need to replace my chain and sprocket....i seen peoples sig with things like -1 -5 for there sprockets...what does that mean....
and when i was looking for sprockets on Vortex racing there was a thing called 520 conv...what is that and whats the diffrence from stock chain and sprocket?
thanks
Old May 1, 2009 | 01:47 AM
Aken's Avatar
July 2008 ROTM
Search search search...
https://cbrforum.com/forum/f4i-main-forum-11/520-conversion-91779/
Old May 1, 2009 | 02:12 AM
hondarider600's Avatar
520 is smaller than stock. the -1 +5 thing is how many teeth from stock you are in the front and rear Ex. my bike is 1 tooth down from stock in the front and it is 2 teeth up from stock in the rear. Goin 1 down in the front is compared to about 3 up in the rear. Doing this will give you lower end power and quicker acceleration but lower top speed and if you switched it around it would be vice versa. Hope that helps a little.
Old May 1, 2009 | 02:17 AM
skoobydoobie's Avatar
520 is the width of the chain. Smaller than the stock 525 (width) and not as strong. 530 is even wider and stronger (used on litre bikes and busas) the whole -/+ thing is the difference in tooth count from stock. i.e. the F4i has a 16 tooth sprocket up front and a 46 tooth on the rear, so a -1/+2 has 15 teeth on the front and 48 out back. Its done for more bottom end torque (easier to wheelie) but high speeds will run your bike at a higher RPM. check ebay for the best prices. I went through "moto-heaven" (ebay store) very knoledgable and will tell you what gearing to use for what you want to accomplish.
Old May 2, 2009 | 04:23 AM
nakedcivic's Avatar
ty guys this is exactly what i need to know
YunMing
Sep 28, 2013 12:45 PM
Myfirstcbr
Mar 22, 2013 09:40 AM
rider0033
Jul 18, 2008 03:57 PM
bignibb
Sep 9, 2007 10:34 PM
