chain noise
Old Feb 25, 2009 | 09:19 AM
chiefF3's Avatar
Default chain noise
so my chain is lubed and tight and everything seems straight but when the bike is on a stand an i have the bike in gear there is a "hitch" in the chain at one point that cause the chain to slow down the speed back up... like a hesitation or glitch in teh chain.. any ideas? ANyone see this before?
Old Feb 25, 2009 | 09:28 AM
jonld's Avatar
how tight is it? do you have the proper amount of play?
Old Feb 25, 2009 | 09:33 AM
chiefF3's Avatar
it is nice and tight and yes there is proper play but it did the same thing when it was loose also
Old Feb 25, 2009 | 01:58 PM
maximus3's Avatar
How old is the chain? I have similar to what you said but on my its cause of the rubber peise on there but it doesn seem to slow down at all on my
Old Feb 25, 2009 | 03:07 PM
chiefF3's Avatar
idk how old it is but im sure its due to poor maintainnece i will be buying a new chain once money allows until then im just gonna ride cause well i can handle a slight noise
Old Feb 27, 2009 | 10:58 AM
chiefF3's Avatar
so after further investigation there is a twist or bend in my chain
i got my rear stand out lifted the bike and used a wrench on the front sprocket to spin my chain and when the chain rotates to a certain place you can see two or 3 links of the chain starting to turn off the sprocket..
at first i thought it was the sprocket but that section of the sprocket hits all of the chain and is fine until that one point... so there is $150
Old Feb 27, 2009 | 11:43 AM
alloutf4i's Avatar
Make sure you check the sprockets, because if it was riden long enough on the damaged chain chances are the sprockets were damaged too. We all know what damaged sprockets means.
Old Feb 27, 2009 | 02:45 PM
chiefF3's Avatar
all of the teeth on the sprockets are straight and not alot of wear... it looks like someone got new sprockets old chain.
Old Mar 18, 2009 | 11:48 AM
chiefF3's Avatar
Talking
good news....
so I got a new chain.... the parts manual i ordered from had the wrong size chain, it has a 525 112 link listed. www.ekchains.com has it listed at the 525 108 link for the 02 cbr f4i. so after breaking a master link clip and removing the 4 extra links. I got hte chain on tight and ready to go
got it on the stand let it run got up to about 20 mph in second gear and no hitch or noise coming from the chain very happy!
now msf this weekend and im all legit!
mikey49
Aug 1, 2009 01:23 AM
four4fish
May 30, 2008 12:36 AM
RCR
Apr 27, 2008 07:27 AM
jdschmidt
Feb 3, 2008 05:19 PM
city worker
Apr 30, 2006 06:33 PM
